Activity Forums Apple Final Cut Pro Legacy giant pixels
  • Posted by Dan Gilsdorf on February 5, 2011 at 3:36 am
    I am hoping to downsize a 16:9 aspect ratio clip down to only 16 by 9 pixels and then blow it back up to regular size (720 X 480) so that all that is left on the screen are 9 rows of 16 big rectangles that change colors to reflect the colors of the original clip. Is there a way to do this using Final Cut? I tried outputting to a custom size (16×9 pixels) but my computer couldn’t read the resulting QT file. As a last resort I can output a still of each frame, manipulate it in photoshop, and re-import the images as an animation but this will take a mighty long time. Any other ideas? Thanks!
    Dan Gilsdorf
    https://www.dangilsdorf.com
    Andrew Rendell replied 15 years, 3 months ago 5 Members · 4 Replies
  • Zane Barker
    February 5, 2011 at 8:02 am
    Use compressor.
    **Hindsight is always 1080p**
  • Rafael Amador
    February 5, 2011 at 9:31 am
    Why don’t you just apply a “Mosaic” filter?
    That is what it does.
    Rafael
    http://www.nagavideo.com
  • Jeff Greenberg
    February 5, 2011 at 5:06 pm
    All inside of FCP? Sure. I tried this. FCP was VERY unhappy with me when I did this.
    Create a sequence. Open Sequence settings (CMD 0)
    Set it to the following: Custom Aspect ratio. Width 32 Height 18 (I wanted to do 16×9, but who knew FCP won’t let you do any numbers below 16?)
    Pixel aspect Ratio Square
    No Field Dominance.
    Put your footage in that sequence.
    Then throw it into a regular 16×9 DV NTSC anamorphic sequence. You’ll get 32×18, but it’s pretty much what you wanted.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Andrew Rendell
    February 14, 2011 at 5:04 pm
    Try sending the shots to Motion and use the Pixellate filter.
