Activity › Forums › Maxon Cinema 4D › GI flicker wont go away.. tried everything
Posted by Daniel De silva on March 20, 2018 at 2:17 amHi everyone,
So in my scene, there are small clustered, white dancing flickering artifacts from certain angles on my model as it rotates.
I’m aware this is a GI issue, but i’ve tried everything to no avail. Different large, small and medium irradiance caches, small medium large sampling, turning up the raytraced hard shadow samples.
But nothing seems to beat it.
Any ideas clever people of Creative Cow?
Dan.
Steve Bentley replied 8 years, 6 months ago 3 Members · 6 Replies -
Steve Bentley
March 20, 2018 at 7:07 amThese might be perfectly flat poly’s (I know, I know, all poly’s are perfectly flat) but I mean to the camera’s eye. A perfectly flat poly will only reflect a single pixel of a reflection map adn sometimes the same goes for a shadow map. So as the angle of incident changes as the camera moves, it’s like you are dragging that reflection map across an opening that is only 1 pixel wide and that one colored pixel is getting plastered over the entire poly no matter how big it is. That pixel will change drastically as it moves.
Try adding either a subtle bump map of noise to the texture (standard noise scaled to 1000 and set to 2 in the bump strength) or try increasing your angle value in your phong tag on the object to “round” things out. -
Daniel De silva
March 20, 2018 at 7:56 am -
Steve Bentley
March 20, 2018 at 8:07 amIt might be how the various textures assigned to the different sets of polys are being mapped. Did you texture it? or are these textures imported from a the CAD package?
It might also be that many cad packages use Z for “up” in the geometry but that change in orientation doesn’t always translate to the textures when they get converted. So a front facing plane that had a logo it might now be a front facing plane with the logo being projected from above – hence only showing up on a razor’s edge or worse, smearing down across the front face.
It could also be that not all the polys were captured in the select (or they have been reordered on import) and you are either seeing through empty polys, or seeing non textured polys or seeing a pixel from the outside edge of the texture mapping dead center on the model.
Steve Bentley
March 20, 2018 at 8:08 amcan you upload a little movie of the effect? We might be able to say “oh I know what that is” once we’ve seen it.
Justin Thomson
March 20, 2018 at 2:55 pmCould it be the model itself? It looks pretty messy, anyway you could upload it? *Edit sry I did not read your earlier post
Steve Bentley
March 20, 2018 at 6:34 pmI think Justin is right – when I first looked I thought I could see through the model and hence those crossing lines were lines on the back faces. But on further inspection it looks like you have overlapping faces inhabiting the same planes. C4D will randomly pick which face is most forward resulting in a sparkling look.
