Activity Forums Adobe Premiere Pro Ghosting Problems
  • Ghosting Problems
    Posted by Jonathan Reed on February 4, 2021 at 2:49 pm
    https://youtu.be/xZ3RoTGOCNM
    So I’m working on a project and I keep on coming across this problem. There’s a ghosting problem on the second clip. This is happening on multiple clips but it seems to be only on pans like so, almost exclusively involving trees. There are the occasional ghosting or even like jump cuts when a character turns really fast. Oddly enough, this only happens when I export to “match Source – High Bitrate”, not when i export to a youtube 720 (I was using to save export time as an example for full vid)
    This projects initial videos’ FPS were all over the place, So I transcoded them to the same FPS.
    This clip initially.
    MPEG-4 (Base Media): 748 MiB, 50 s 160 ms
    1 Video stream: AVC
    Duration: 50 s 160 ms
    Overall bit rate: 125 Mb/s
    Writing application: Lavf58.20.100
    Video: 125 Mb/s, 7680*4320 (16:9), 25 FPS, AVC (HIgh@L6) (CABAC / 1 Ref Frames) Autel.Video
    Transcoded to:
    MPEG-4 (Base Media): 619 MiB, 50 s 134 ms
    1 Video stream: AVC
    Duration: 50 s 134 ms
    Overall bit rate: 104 Mb/s
    Writing application: Lavf58.12.100
    Video: 104 Mb/s, 7680*4320 (16:9), 23.967 FPS, AVC (HIgh@L6) (CABAC / 3 Ref Frames) Autel.Video
    Sequence Settings:
    FPS: 23.976, 7680 x 4320 (1.0), 48 Hz – Stereo
    Exported to:
    7680:4320 (1.0), 23.976 fps, Progressive, Software Encoding, VBR, 1 pass, Target 10.00 Mbps, Max 12.00 Mbps AAC, 320 kbps, 48 kHz, Stereo.
    Please help, I don’t know what’s happening, why it’s happening, how to avoid this in the future, how to fix it now.
    Thanks for all your help. I really appreciate it.
    Please let me know if you need more information.
    Jonathan J.R. Reed
    Todd Perchert replied 5 years, 7 months ago 2 Members · 1 Reply
  • Todd Perchert
    February 9, 2021 at 4:32 pm
    This is due to your frame rates and premiere trying to blend frames when converting to a different frame rate. It will be most noticeable between frame rates that really are not compatible. Like trying to go between 25fps and 23.976fps. I doubt you’ll get results that you want. But you can always try editing the original footage into your sequence, then right-click the footage in your sequence and try changing the Time Interpolation to see if you get decent results. Also, you can right-click on the clip in your bin, prior to editing into your sequence, and select Modify / Interpret Footage and change the frame rates of the clips to match your sequence – then edit in.
    Good luck!
    TC
