Activity Forums AJA Video Systems “Ghosting” on downconverted text
  • “Ghosting” on downconverted text
    Posted by Tim Mclaughlin on March 17, 2008 at 10:45 pm
    Okay, now I have a new term for what I’m seeing.
    From August last year:
    Re: Downconvert/Field Issues-Upper vs Lower?—ANYONE??
    by Kevin Wild on Aug 15, 2007 at 12:32:54 pm
    Just to be clear, the ghosting images we are seeing have nothing to do with HDV. It does it on the downconvert period, regardless of codec. I even tested uncompressed HD. Also to be clear, this is using the KonaLH. It’s possible it’s not an issue on the Kona 3. We have 3 LHe’s and they all do it…as does the one at AJA tech support.
    And also:
    by John Pale on Aug 16, 2007 at 9:51:49 pm
    I see it on my Kona 2, for what its worth. have not found a workaround.
    Okay – this is EXACTLY the problem I’m seeing. I can’t imagine that Walter or Gary would put up with this kind of image degredation on their masters going to air.
    I doubt Bob Z. would install so many AJA cards if they had this problem.
    I’m in contact with AJA tech support, but so far they seem to think that this problem occurs because my source footage is DVCProHD.
    I have a VERY hard time believing that.
    I cut some sample footage into an uncompressed 720p HD sequence (with animation codec titles), rendered it, and it still looked like crap on titles.
    The footage was gorgeous, the titles were ghosted.
    Someone please shed some light on this. I’m losing my mind.
    Tim McLaughlin
    Avid and Final Cut Pro Editor
    Jason Lyons replied 17 years, 11 months ago 9 Members · 16 Replies
  • 16 Replies
  • Tim Mclaughlin
    March 17, 2008 at 11:58 pm
    Forgot the details:
    FCP 5.1.4
    OS 10.4.10
    Quad Core G5 2.5 GHz
    Kona 3 with K-box
    Downconverting DVCProHD 720p via HDSDI to DVW-500.
    All standard def stuff looks GREAT. 10 bit Uncompressed SD does NOT have this problem.
    This seems to be a down conversion problem only.
    Tim McLaughlin
  • Paul Provost
    March 18, 2008 at 3:12 pm
    are you downconverting by just rendering out in an fcp timeline, or are you downconverting an hd timeline using the Kona card output to a deck?
    Paul Provost
    http://www.postandbeam.tv
  • Tim Mclaughlin
    March 18, 2008 at 3:47 pm
    Downconversion is happening entirely through the Kona 3 card.
    I’m performing “edit to tape” from my HD timeline and having the Kona card downconvert via SDI as either letterbox or anamorphic and add the pulldown.
  • Arnie Schlissel
    March 18, 2008 at 4:04 pm
    I have not seen that going from a 720P timeline to beta via the component out on a Kona 3.
    What kind of monitor are you using for the downconvert? I try to monitor downconverts on a CRT, the LCD that we use doesn’t show the whole story with SD interlaced footage.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Aaron Neitz
    March 19, 2008 at 4:43 pm
    Now I’m confused… you said you were using Kona LHe or Kona 3?
    Can you digitize a digibeta that you made with these ghosted text and post a still image for us? I think that’ll help tremendously.
  • Aaron Neitz
    March 19, 2008 at 4:46 pm
    Also like I asked earlier, are you certain you have broadcast safe titles?
    The only reason I ask is on an old project for HDCAM-SR which we were peaking at 110 (this was for filmout, no broadcast safe needed to be adheared to) any downconvert to SD showed a weird ghosty/ringy quality in solid graphics and gradients. Disclaimer: this was using a Blackmagic card
  • Gary Adcock
    March 19, 2008 at 5:12 pm
    [Aaron Neitz] “Also like I asked earlier, are you certain you have broadcast safe titles? “
    Aaron
    Good question, I would Like to also ask about the fonts being used. Thin or fine fonts
    do not look good in SD, while the fine detail holds up in HD the inter-field blurring brought on by not having enough data when doing a conversion can bring this on.
    My test – Use a standard title in SD and the same in HD downcoverted should look the same, and in all of my tests they do. Only on very fine text detail when doing an HD downconversion does it break apart or ghost. – it means that your font is NOT suitable for SD viewing.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Tim Mclaughlin
    March 19, 2008 at 6:19 pm
    Thanks for the feedback and questions guys.
    Here is a link to hi-rez JPEG files as well as a zipped archive of TIF files that I’ve compiled.
    One file is the original HD, one is a 10 bit capture from the SD downconvert, and one is a totally unfair comparison by taking the HD frame and resizing it in PhotoShop.
    As a test, I readjusted the levels of the name keys in AE (to a range of 16 to 235), and I was still seeing the same issue.
    I just need an answer on how to fix this – or if it’s even fixable. Am I doing something wrong? Does DVCProHD always look like crap on downconversions? Is there something wrong with my card?
    Tim McLaughlin
  • Aaron Neitz
    March 19, 2008 at 9:44 pm
    Ah, I see
    I see this on downconversions too. It’s a function of that strong primary color, white type, and hard edges. There’s probably some YUV maths involved in going from a 4:2:2 HD space into a 4:2:2 SD space… That’s why Photoshop does such a good job – it’s pre-sampling your HD as 4:4:4 RGB.
    Did you try letting Compressor do a downconvert? Or dropping the HD timeline into an SD with Best rendering?
  • Tim Mclaughlin
    March 19, 2008 at 9:49 pm
    Letting Compressor or FCP handle this makes it look even worse. The interlacing artifacts are terrible.
    I’d take ghosted titles over those 2 options.
    Tim McLaughlin
