Activity Forums VEGAS Pro Ghosting in Vegas platinum
  • Ghosting in Vegas platinum
    Posted by Randolph Bulpin on January 31, 2010 at 2:03 am
    I am learning Vegas Platinum and COW is a great support. The movement in the preview often has ghosting, this seems to be inconsistent and I am wondering if this is just a temporary artifact ie when I render it for final product it will not have the ghosting. I already have rendered the video file from MOV to avi/DV so I can work with it in Vegas Platinum. Any suggestions?
    John Rofrano replied 16 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 31, 2010 at 4:21 am
    Ghosting can be caused by a lot of things. First set the preview to Best Full and see if it goes away. If it does, it’s just a preview thing and won’t be in the final render. It it doesn’t then you need to figure out what’s causing it. It could be caused by a mismatch in frame-rate between your project and the footage. Check that they match. It could have been caused in your MOV to AVI conversion. Vegas can edit DV MOV files so was the conversion really needed? Check the clip in Windows Media Player to see if it’s in the AVI file itself. It could also be motion blur in the original footage. Check the MOV file in Quicktime to see if it’s there.
    If you can post an image of what you see it might help identify what is causing it. Not too long ago someone complained of ghosting and it was actually interlacing on fast moving objects that cause the fields to become very far apart in the 1/60 of a second that they were recorded. It’s always best if we can see what you are seeing.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
