Activity Forums Apple Final Cut Pro Legacy ghosting effects in the sequence
  • ghosting effects in the sequence
    Posted by Joseph Bradley on February 1, 2007 at 11:06 pm
    I have a client that is having some weird problems. He has a G5 dual proc 2.0 and a G4 laptop both running FCP 5.1.1 The biggest problem he has is that every dissolve he does comes out just a little bit brighter than the clips, which make the clip at the end seem to pop in color. The second problem is the he gets what I can only call ghosting effects. Random clips are showing dissolves and test renders where none existed before. If I delete the clip it seems to go away, but, if I put a slug in it’s place the effect comes back. I got it to go away by placing a slug on a different track just above the ghosted effect but since it happens more than the client would like he doesn’t want to do that all the time. I can also copy the seq, into a new seq, and the ghosting goes away. However, when I do the renders that were done in the old seq. go away and I have to render again. I trashed the prefs but it didn’t help. It all seems to be a render problem but I can’t figure what it is. Any help would be appreciated.
    Joseph Bradley replied 19 years, 7 months ago 3 Members · 4 Replies
  • Bouncing Account needs new email address
    February 2, 2007 at 12:46 pm
    [jbrad2] “The biggest problem he has is that every dissolve he does comes out just a little bit brighter than the clips, which make the clip at the end seem to pop in color.”
    My first thought is that this sounds like a “White vs. Super White” issue.
    Touch the right-hand Canvas window (to activate the timeline you are working with.)
    Hit “Apple-0 (zero)”
    Click the “Video Processing” tab.
    Make sure your Process Maximum White as: is set to “White”
    and select “Render in 8-bit YUV”.
    Then re-render your effects.
  • Tom Wolsky
    February 2, 2007 at 12:54 pm
    What are the specs on the clips? Where’d they come from?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Joseph Bradley
    February 2, 2007 at 5:04 pm
    Hey, Tom
    The clips are in JPEG. He likes to use that codec for his offline work.
  • Joseph Bradley
    February 2, 2007 at 5:10 pm
    I don’t know what the footage was shot on but it was captured in this codec. He is using white and not super white but I didn’t look to see whether he is rendering in 8bit yuv. I’ll check with him.
