Activity Forums Apple Final Cut Pro Legacy Ghosted Soundtrack Pro Audio File Project
  • Ghosted Soundtrack Pro Audio File Project
    Posted by Thom Sullivan on May 23, 2007 at 9:26 pm
    For some reason when an audio track is selected to send to Soundtrack Pro, Send To ‘Soundtrack Pro Audio File Project’ is ghosted and cannot be unghosted. Can anyone help with this problem? By saving the audio track as an AIFF file it can be opened in Soundtrack Pro and edited as though it intended to be through the Soundtrack Pro Audio File Project route.
    Thank you for any assistance.
    Thom Sullivan
    Comcast Cable
    Jeremy Garchow replied 19 years, 4 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    May 24, 2007 at 1:31 am
    try sending a multitrack sequence. Audio file projects are for single clips to be edited. When you send the multitrack, you can then edit each clip individually.
