Activity Forums Adobe Encore DVD ghost image
  • ghost image
    Posted by Dan Asselin on September 2, 2006 at 9:34 pm
    I just lost the biggest authoring contact I have ever obtained to an error which i just can’t figure out. I am using adobe encore and every time I attempt to transition between clips on the dvd the disc pauses and leaves a “ghost image” of the final visible frame from the previous clip before moving to the next clip. This only seems to happen when the transition is a fade to…and out of…black. I tried adding extra frames of black to the beginning and end of all clips to no avail. To say that I am disappointed is to put it mildly. I am obviously not under any time constraints here because I have already blown my opportunity but if anyone has any ideas as to how I can avoid this in the future it would be appreciated.
    Thanks;
    Dan
    Dan Asselin replied 19 years, 12 months ago 2 Members · 4 Replies
  • Joe Bowden
    September 3, 2006 at 1:49 pm
    What version of Encore are you using?
  • Dan Asselin
    September 3, 2006 at 3:47 pm
    Encore 1.5. My system is P4 2.8 1.5 Gig Ram and i am burning using a sony dual layer drive.
    TNX…..Dan
  • Joe Bowden
    September 4, 2006 at 4:49 pm
    You need to go back to Premiere, uncheck “optimize stills” in the AVI export dialog, and then re-export. Or export an MPEG-2 from Premiere.
    “Optimize stills” is supported in Encore 2.0.
  • Dan Asselin
    September 4, 2006 at 10:24 pm
    Thanks Joe……Makes sense…I’ll try it at my earliest opportunity.
    Dan
