Activity › Forums › Apple Final Cut Pro Legacy › “Ghost” clip in FCP project
  • “Ghost” clip in FCP project
    Posted by Nathan Hartswick on April 19, 2007 at 11:32 am
    Hi gang,
    Working on a project and I have this one little video clip that appears on the same point of the timeline no matter what I do. The kicker is, it’s totally invisible. It must be a leftover, cache type thing.
    All my video tracks are set to be visible, and I even tried deleting the actual source file to the clip that was appearing. No dice.
    Someone told me to “trash my preferences,” but I haven’t been able to figure out how to do that (and I’m leery of messing up my project).
    I have version 5.1.4.
    Any advice?
    THANKS!
    Nathan
    Ronald Baragona replied 16 years, 1 month ago 5 Members · 6 Replies
  • Steven Gonzales
    April 19, 2007 at 12:57 pm
    https://docs.info.apple.com/article.html?artnum=302337
    Final Cut Pro: Troubleshooting Basics
  • Nathan Hartswick
    April 19, 2007 at 1:16 pm
    Thanks for the link! I tried doing that – cleared out my user preferences, and I’m still seeing the clip.
    Any other ideas, short of reinstalling the program?
    Nathan
  • David Roth weiss
    April 19, 2007 at 1:33 pm
    Nathan,
    I think this is a render file gone bad, not your prefs gone bad. Go to the Render Manager in the Tools drop down and delete the render files and rerender that timeline. That should fix your issue.
    DRW
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Nathan Hartswick
    April 19, 2007 at 3:04 pm
    Bingo! That fixed it. Thanks SO much. Lotta smart folks here; I’ll be back.
    Cheers,
    N
  • Ben Holmes
    April 20, 2007 at 7:34 pm
    You’ll find that renders sometimes linger on the timeline in FCP5. Another example is copying a clip that had a transition on it (but not copying the transition itself) then pasting it elsewhere. The (for example) dissolve that was originally happening still appears on the end of the clip until it is re-rendered, if the clip itself required rendering, and has been pasted with the render still in effect. Make sense?
    Sometimes, I’ll turn a filter on and off just to force a re-render to get around these ghost renders – just as a workaround.
    Hopefully a ‘bug’ gone in FCP6…
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    New HD edit/slomo truck on the road this month. Dual FCP systems/6 slomo positions.
  • Ronald Baragona
    August 8, 2010 at 2:34 pm
    Got a problem on a timeline. Need your expertise.
    im not sure if its the rendering process that is the problem. but it when I insert a clip in a certain timeline, there seems to appear another clip of 29frames and then it goes back to show the clip i inserted. but when i remove the video clip and go over that specific timeline, i could not view the 29-frame clip. Its just blank.
    And when i preview the clip i was planning to insert in a different time, i could view the entire clip without the 29-frame clip being played.
    Thanks for all the help.
