Activity Forums Panasonic Cameras Gh4 workflow
  • Gh4 workflow
    Posted by Zimema Mhone on October 22, 2015 at 8:49 pm
    i have just collected a bunch of footage documenting the Finnish summer and I would like to get some advice as to how to start ‘processing’ the footage.
    The goal is to create a travel montage, which includes a lot of speed ramping, positioning and stabilization. The focus of the piece will be the interaction between the images, effects and sound. They are all equal in importance.
    I intend on pursuing a workflow as such: select and stabilize clips/ sequences/ events in After Effects, then pre-comp and apply Twixtor as needed, pan & scan/ resize/ crop to 1080p or not, export as prores 444, import to FCPx, put it all together as a fluent series of events and rework effects as needed.
    Can somoene let me know if I am heading for woes or if I am on the right track. What else should I consider?
    Zimema Mhone replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
