Activity Forums DSLR Video GH4 variable Frame Rate 96fps
  • GH4 variable Frame Rate 96fps
    Posted by Lothar Wieland on June 28, 2014 at 6:20 am
    If I record with the GH4 in variable frame rate @96fps Premeiere Pro or AE shows only 24fps….I’m not sure if I handle the gh4 setting right or is it an issue with handling variable framerates in editing systems. Does anyone has experience with it?
    Lothar Wieland replied 12 years, 2 months ago 2 Members · 2 Replies
  • Brian Mulligan
    June 30, 2014 at 5:35 pm
    The QT is flagged as 24 and therefore plays in slomo by default. You can go in to PP or AE and interpret the footage on the clip to be 96fps and then it will play in real time.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Lothar Wieland
    June 30, 2014 at 6:26 pm
    Thanks!!!
