Activity Forums Apple Final Cut Pro Legacy gfx change on render
  • gfx change on render
    Posted by Mitchell Goldman on September 17, 2008 at 4:37 am
    I am hoping that someone can explain this one to me:
    – I have brought a powerpoint slide show into fcp6.0.
    – I make a freeze frame out of a particular frame in the ppt.
    – I bring it into the sequence; it looks exactly as it should.
    – I render it and it becomes a completely different slide from the same ppt.
    (btw, it didn’t just happen once; it seems to happen every time.)
    is there any reason that fcp6.0 should not be frame accurate? is there a reason that this is shifting in this way?
    Thanks for giving this your consideration,
    Mitchell
    Mitchell Goldman replied 18 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 17, 2008 at 6:58 am
    [Mitchell Goldman] “is there any reason that fcp6.0 should not be frame accurate”
    FC is frame accurate when there is TC. PP don’t think support it.
    I have no idea FC could import PP docs. i think you can export the PP as a .mov and bring it to FC.
    rafael
    http://www.nagavideo.com
  • Mitchell Goldman
    September 22, 2008 at 1:48 pm
    That did the trick! big thanks–
