Activity Forums DaVinci Resolve Getting Timeline to start at 00:00:00:00 ??
  • Getting Timeline to start at 00:00:00:00 ??
    Posted by Nigel Cooper on December 4, 2020 at 12:04 pm
    I’ve gone into Resolve ‘Preferences’ and set the ‘User/Editing’ ‘Start Timecode’ to 00:00:00:00, however, project still starts at 01:00:00:00, any ideas?
    Closing Resolve and re-starting retains my User settings, but existing and new projects insist on starting Timecode at 01:00:00:00, which is a drag for my workflow, any ideas?
    Nigel Cooper replied 5 years, 9 months ago 3 Members · 4 Replies
  • Jostein Svalheim
    December 4, 2020 at 2:02 pm
    I currently don’t have DaVinci installed, but I’m pretty sure it will show 01:00:00:00 until you have imported clips into the timeline, no matter what the default is set to. After that it will show correctly.
  • Nigel Cooper
    December 4, 2020 at 2:15 pm
    Nope, still shows with extra minute tagged at beginning, regardless.
  • Joseph Owens
    December 4, 2020 at 3:35 pm
    “extra minute”…?
    1:00:00:00 is one hour, and is basically an industry standard designed to avoid negative time. Basically because there was a convention to add test signals, slate, countdown &c. prior to Program Start *in the olden days.* I was never that fond of it myself because it messes up some synchronization with leader occasionally for Non-Drop uni-clip media in Drop Frame sequences.
    Many broadcasters require a starting time code of 10:00:00;00, but that probably isn’t going to be an issue here either.
    Right-click on the timeline in the assets bin. It will bring up a Timelines> dialog that includes “Starting Timecode” and you can set in anything from 00:00:00:00 to 23:59:59.NN depending on what your frame base standard is.
    JPO
  • Nigel Cooper
    December 5, 2020 at 2:07 pm
    Great, sorted, thanks.
