Activity Forums Adobe After Effects Expressions Getting this to work in 3D space?
  • Filip Vandueren
    July 6, 2005 at 10:09 pm
    Hi Ian,
    The recipe that would work best is to have the moving around layers in 3d,
    but the lines (beam-filter) that connect them need to be applied to a 2D layer that is as big as the comp and is drawn on top of the 3d-layers.
    The expression trick is that the 2d-layer needs to know what the equivalent position of the 3d-positions is in 2D.
    (this is what’s called: a layer space transformation.)
    Dan Ebberts has the theory all explained on his wonderful site ‘motionscript.com’:
    https://www.motionscript.com/mastering-expressions/lst-lens-flare.html
    basically where in 2D you normally would wind up with an expression like this:
    thisComp.layer(“object 1”).position
    you now need something like this:
    thisComp.layer(“object 1”).toComp(thisComp.layer(“object 1”).anchorPoint);
    Check out Dan’s Site
    He can explain it best 😎
  • Nathan Clark
    December 23, 2009 at 10:28 am
    Hello, sorry to wake up a VERY old thread, but I am breaking my brain trying to get this to work in a slightly different way.
    The 3d Nulls I would like to connect with the BEAM effect are in a precomp with collapse transform turned on.
    I cant work out the method to get their 2d position in the main comp for the beam effect.
    this is irritating me because I know it should be quite easy, my math brain is just useless at times!
    Any support would be appreciated.
    On Point Cloud Nine
