Activity › Forums › Panasonic Cameras › Getting the Correct Shutter Speed
  • Getting the Correct Shutter Speed
    Posted by Dan Pavlik on September 25, 2009 at 7:49 pm
    Hi.
    I’m working with the HPX170.
    When I toggle through the shutter speeds, it cycles from 1/24 to 1/1000, but it does not have a 1/48 setting when in “film cam” mode.
    Many “film looks” call for 1/48, so how do I achieve that?
    thanks,
    Dan
    Hi I’m Dan. My current project is a feature comedy entitle Nominated. You can learn about it at http://www.nominatedthemovie.com
    John Fishback replied 17 years ago 4 Members · 3 Replies
  • Emre Tufekci s.o.a.
    September 25, 2009 at 10:11 pm
    If I am not mistaken when the shutter is in off position it should be at 1/48. Thats how it is for the HVX200 (I think).
    Emre Tufekci
    http://www.productionpit.com
  • Jeremy Garchow
    September 25, 2009 at 11:59 pm
    Is there a setting for ‘half’? There is on the 2000. I think off is 1/50th.
  • John Fishback
    October 2, 2009 at 9:40 pm
    I’ve also seen 180 degrees.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
