Activity Forums Adobe After Effects Getting the Best out of Mulit Processing
  • Getting the Best out of Mulit Processing
    Posted by Raine Vivian on September 15, 2011 at 7:40 pm
    So I recently got a new laptop (an Asus G74sx) which has a quad i7 core, and currently 8 gigs of RAM.
    Every time turn on the multi-frame processing, after effects (CS5.5) seems to have a really read time with it. Most of the time I just have to turn it off. Any suggestions on settings? (for some reason it says I have 8 cores installed) Here is what I have it set to now:
    CPU’s reserved for other applications: 1
    RAM allocation per background CPU: 2GB
    Actual CPU that will be used: 2
    Any ideas? Thanks guys!
    -Raine Vivian
    http://www.rainevivian.net
    http://www.seaboundesign.com
    Raine Vivian replied 15 years ago 3 Members · 3 Replies
  • Walter Soyka
    September 15, 2011 at 7:46 pm
    Your i7 has a feature called hyperthreading, which creates 2 virtual cores for each physical core in your machine.
    AE needs a lot of RAM for multiprocessing. Each render instance (number of CPUs/cores used) requires its own, and I still use 2-4 GB per core as my rule of thumb, plus a decent amount of RAM for system overhead. If you don’t have enough RAM, multiprocessing will actually render slower than non-multiprocessing.
    To use 4 cores, I’d recommend having 16 GB of RAM.
    If you can add RAM to your machine, that will improve your multiprocessing significantly. If not, you should probably leave it off.
    Walter Soyka
  • Michael Szalapski
    September 15, 2011 at 8:32 pm
    I’m with Walter, you’re on the edge of being able to use Multi Processing. You will have to try a bit of tweaking to see if you can get it to work. Perhaps this post will give you some ideas on where to start. [Link] Don’t forget to check the thread linked in it. Tons of people with various setups posting their findings.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Raine Vivian
    September 15, 2011 at 9:42 pm
    Yeah, I was thinking about upgrading to 16 gigs. Okay great, thank you guy for your input. I really appreciate it. I’ll try and remember to update this post when I get more Ram. Thanks again.
    -Raine Vivian
