Activity Forums Apple Final Cut Pro Legacy Getting strange PAL error after export
  • Getting strange PAL error after export
    Posted by Sports Chica on December 19, 2008 at 6:44 pm
    I’ve been trying to export a sequence out of Final Cut Pro to burn on a DVD. I’ve tried two ways… once as a QuickTime movie and also through Compressor as a DVD Best Quality. No matter which way I export it, when I attempt to import it into DVD Studio Pro I get a “Cannot use PAL” message. I have no idea how this got edited as PAL. When I look at all of my system preferences, it’s all NTSC.
    Does anyone have any ideas as to why this is happening? I’m needing to get this DVD off to a client ASAP for their final approval.
    Gary Adcock replied 17 years, 9 months ago 6 Members · 11 Replies
  • 11 Replies
  • Nick Holmes
    December 19, 2008 at 6:48 pm
    You need to set up DVD Studio Pro to work in PAL. Everything you need is in DVDSP’s Preferences.
    Nick
  • Sports Chica
    December 19, 2008 at 7:24 pm
    I’m sorry I didn’t make this clear in original posting. I don’t want it in a PAL format. I’ve always worked in NTSC and I have never had the need to use PAL. So I’m scratching my head as to why all of the sudden my export from Final Cut is in a PAL format. There is no indication it’s in PAL until I attempt to import it into DVD Studio Pro.
    Sports Chica
  • John Pale
    December 19, 2008 at 8:35 pm
    Open what you exported in Quicktime Player.
    Does it say it is PAL?
  • Paulo Jan
    December 19, 2008 at 10:12 pm
    Here’s a very very silly suggestion: have you checked your sequence settings in FCP? Is it possible that you might have started the project with a PAL sequence by accident?
  • Sports Chica
    December 20, 2008 at 7:11 pm
    That’s the thing that has me scratching my head. When I looked at my system preferences they were as follows:
    Sequence preset – DV NTSC 48 kHz – 23.98
    Device Control – Firewire NTSC
    Capture preset – DV NTSC 48 kHz
    When I look at the quicktime file there is no mention of PAL. Same goes for the compressed file I did.
    I’m stressed that I’ll have to edit the whole thing over again. My client is expecting it Monday or Tuesday. And if I have to do it all over again, what do I change my presets to so it doesn’t happen again?
    Sports Chica
  • Sports Chica
    December 20, 2008 at 7:13 pm
    It doesn’t have anything about PAL. It just lists Quicktime movie 1.56 GB.
    Sports Chica
  • Nick Holmes
    December 20, 2008 at 11:45 pm
    What does QuickTime Player report the framerate as?
    Nick
  • Gary Adcock
    December 21, 2008 at 2:47 am
    [Sports Chica] “Sequence preset – DV NTSC 48 kHz – 23.98 “
    but this is not PAL
    this is NTSC.
    DV PAL is 25p/50i at 720 x576 upper field first
    DV NTSC is 29.97 at 720×480 lower field first.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Andy Mees
    December 21, 2008 at 4:26 am
    i’m guessing just a typo, but just to clarify fro the OP:
    DV PAL is 25p/50i at 720 x576 lower field first
  • Sports Chica
    December 21, 2008 at 5:41 pm
    I think I’ve discovered the problem. On the QT it is FPS 25, Size 1440×1080, format H.264
    I recently edited on HD format. This project is regular DV. Even though I changed my video and audio formats back to DV from HD, the sequence is set up for HD 1440×1080, but the media is 720×480.
    Sports Chica
