Activity › Forums › Adobe After Effects Expressions › Getting sourceRectAtTime() for first line in multiline text.
  • Getting sourceRectAtTime() for first line in multiline text.
    Posted by Daniel Annefelt on October 15, 2020 at 8:45 am
    Hello!
    I’m using a sourceRectAtTime() expression to position a bug top-left over a text.
    Kind of like this:
    CRUSH
    It works as like a charm – the bug stays in place regardless of text length.
    But sometimes I need a 2 (or 3) line text.
    This also works as long as the next line are the same length or shorter.
    Like this:
    CRUSH
    MUCH
    But if second line is longer obviously the whole text box expands
    and the bug will be positioned according to size of the whole text box.
    Like this:
    CRUSH
    LOLLAPALOOZA
    But I want this:
    CRUSH
    LOLLAPALOOZA
    So – question.
    Is there a way to read textbox position info from only the first line in a multiline text?
    cheers!
    .::Daniel
    Daniel Annefelt replied 5 years, 11 months ago 3 Members · 5 Replies
  • Brendon Murphy
    October 15, 2020 at 7:08 pm
    Daniel,
    I can’t really see the issue you’re having… are you able to use the anchor point location or a null to position your bug?
  • Daniel Annefelt
    October 15, 2020 at 9:10 pm
    I have a multiline text.
    I want to lock my graphic layer to the first line.
    Not to the consecutive lines.
  • Filip Vandueren
    October 18, 2020 at 10:14 pm
    I think the easiest would be to have a hidden text-layer that copies all the properties of the first one, but with an expression on sourceText so it only shows the first line.
    (Or you can set it up with a textanimator that sets everything except line 1 to scale 0)
    Then use the sourceRect of that layer.
  • Daniel Annefelt
    October 20, 2020 at 7:50 pm
    Nice!
    Sounds clean and relatively easy.
    Thanx
    .::D
  • Daniel Annefelt
    October 21, 2020 at 8:36 am
    Yes – the scale animator worked!
    Also set the units to Index based on Lines under Advanced.
    Thanks again.
    :::D
