Activity › Forums › Adobe After Effects › getting smooth dissolves
  • getting smooth dissolves
    Posted by John Graves on August 28, 2009 at 6:55 am
    Simple question. I want to cross dissolve between two almost identical, mostly white layers. A title is fading on. Yet, in linear mode, when i opacity from 100 to 0 on one layer and from 0 to 100 on the other layer, I am getting a dip in density, i.e. the white fades down a little bit during the dissolve. The keyframes are in linear. Fixed areas are specified as hold frames.
    If I pull the bezier handles to get a logarithmic curve, it more or less smooths out the dissolve. Still, that shouldn’t be necessary! Why is this simple operation of a cross dissolve a pain in the neck and what am I doing wrong?
    thank you very much
    John
    “Life is good, as long as it doesn’t take up too much of my time.”
    -anonymous gamer
    Erik Waluska replied 17 years, 1 month ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    August 28, 2009 at 11:14 am
    That’s because AE doesn’t do a simple addition of the opacity values. Try changing your background color to a bright red and you should see part of it. The trick is to ensure that at least one layer is at 100% opacity, then dissolve on the other layer over this.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • David Bogie
    August 28, 2009 at 12:56 pm
    [John Graves] “Still, that shouldn’t be necessary! Why is this simple operation of a cross dissolve a pain in the neck and what am I doing wrong?”
    It’s a common issue with AE newbies. If you do as Rholand suggests and add a layer under your white layers, you will see the bottom layer become visible during that’s because at the middle of the dissolve, both layers are at about 50% opacity. That doesn’t add up to 100%, it means you can see through both.
    To perform a dissolve in AE, you need to think of it as a change in opacity on the upper most layer from 0-100 or 100-0%. That will either reveal or completely obscure the underlying layers.
    bogiesan
  • Erik Waluska
    August 29, 2009 at 4:01 pm
    Just pre-compose the two layers you are cross-fading and set the blending mode on the top layer to “Alpha Add”. In the pre-comp you will still see the dip, but in the main comp where this cross-fading comp is nested the cross-fade will appear correctly with no dip.
    -E
