Activity › Forums › Adobe After Effects › Getting Slider Shots Perfect in Post?
  • Getting Slider Shots Perfect in Post?
    Posted by Terry Nutkins on January 31, 2014 at 4:46 pm
    Hi there,
    I’m working with footage filmed with a slider that is at times a little uneven in terms of the movement/timing and with a bit of shakiness on some shots.
    Would it be easy to smooth these problems out seamlessly in AE (or different software)? Or should I start considering re-shoots with a motorised slider?
    Todd Kopriva replied 12 years, 7 months ago 3 Members · 2 Replies
  • Joseph W. bourke
    January 31, 2014 at 5:31 pm
    The shakiness can be corrected in AE using the Motion Tracker to stabilize the footage. As far as the movement and timing, that’s a lot tougher. The Warp Stabilizer (AE6 – you don’t say which version you’re using)claims to be able to fix uneven motion, but I haven’t tried it for slider stuff. It sounds as if you need a better slider, or better slider operator – a motorized slider will give you the consistency of motion you’re looking for, but if you’ve got audio going on, there’s sometimes a problem with motor noise.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Todd Kopriva
    January 31, 2014 at 7:34 pm
    I show how to make a dolly pan smoother using the Warp Stabilizer effect in this video:
    https://www.video2brain.com/en/lessons/overview-of-warp-stabilizer-effect
    After Effects team blog
