Activity Forums VEGAS Pro getting rid of loop feature on timelineL
  • getting rid of loop feature on timelineL
    Posted by Brian Langtry on December 3, 2016 at 3:08 pm
    Hi
    Just a quick word of thanks to Mike, Marco and Laszlo for the advice. Interestingly I could find no mention of this using the in built ‘help’ feature. Its always simple when you know how!! Derrrrrrr!
    John Norton replied 9 years, 9 months ago 2 Members · 1 Reply
  • John Norton
    December 4, 2016 at 12:41 pm
    I copied this from some other posting, in case u want to re-enable in future …
    Also, you can use the keys I and o to remove the yellow markers … i alone works if you use it immediately after creating the loop, and you dragged right to create it. If you dragged left then it would be o that works alone. And if you’ve moved the cursor at all since creating the loop then you’ll need both i and o.
