Activity › Forums › Apple Final Cut Pro › getting rid of duplicate files in my library
  • getting rid of duplicate files in my library
    Posted by Wendy Andersen on April 16, 2015 at 6:05 pm
    I have footage from 5 different cameras, delivered on several different drives, and in an effort to make sure nothing was overlooked, I managed to copy in a lot of the clips twice.
    I can see them in the list (organised by date). So I can select every other file and delete it, but there are hundreds of them: making my library nearly double the size it should be, and I’m worried that if I don’t delete them before editing – I will be stuck with them for fear of deleting the used copy.
    But short of “CMD select”-“move to trash”-“are you sure?” repeat, repeat, repeat, 500 times…
    Is there an easier “delete all duplicates” command, hidden somewhere…
    please?
    Noah Kadner replied 11 years, 5 months ago 4 Members · 5 Replies
  • Matt Trubac
    April 17, 2015 at 2:57 am
    Did you import everything on the same date? Hopefully no. Toward the bottom of the library there are some sort / group tools, and I believe you can group by date imported.
  • Matt Trubac
    April 17, 2015 at 3:01 am
    Or maybe.. Quickly go through and assign a rating or reject the dups and then view only the assigned rating or rejects and delete them all from your event at once.
  • Wendy Andersen
    April 17, 2015 at 10:09 am
    Hi Matt,
    Thanks for your suggestions.
    Unfortunately I did import them all on the same day.
    The dups were all over the place, not just every other file – so not really possible to mark them all up simply (for deletion or for rating). In the end I went through and deleted all the individual duplicates – 500 of them, on both the main drive and backup!
    If any one else has any suggestions I’d still be interested to hear for the future.
    (Yes I am confident in my ability to repeat my mistake again)
  • Nick Toth
    April 17, 2015 at 1:56 pm
    Put each import in a separate event. Make use of “show used” and “sort by unused” functions.
    anickt
  • Noah Kadner
    April 17, 2015 at 4:46 pm
    I would research the subject thoroughly before making a move- but consolidating your Library would be a big help here.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
