Activity › Forums › DaVinci Resolve › getting rid of a lens dust spot on a close up
  • getting rid of a lens dust spot on a close up
    Posted by Ron Fya on February 25, 2017 at 2:08 am
    Hi Guys,
    The final shot of the music video I’m working on is spotted with lens dust in the very plain center of the face.
    The spot looks like a slightly dark question mark and is still on the image. As she turns her head, it moves from between her eyes, gets through her left eye into her hair above the left ear.
    (See images WGA – lamb meat – spot – 01 to 04, in 16:9)
    How would you deal with that ?
    I tried a power window with a curve but of course, since the source area is changing in luminosity along its path, a setting that kinda gets rid of the spot at one place does not work for the next.
    Moreover, I said “kinda gets rid” of it because despite playing with the softness parameters of the power window, I still gets a fringe around the spot.
    (See images WGA – lamb meat – fix test – 01 to 04 , in cinemascope)
    There are also several smaller other spots on other parts of the image.
    Here is a link to the footage if images are not enough.
    https://we.tl/b1SppYqQpa
    Any quick fix ? Or should I go for the nuclear option and do it in photoshop frame by frame along 160 frames ?
    My deadline is monday I am taking the fastest tricks ????
    Thanks you so much
    Michael Gissing replied 7 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
  • Glenn Sakatch
    February 25, 2017 at 4:41 pm
    the quickest fix is probably a distraction….lens flare coming out of the corner, nothing too harsh, but enough to cause some extra polygons to float around the screen.
    You have lots of color backlight, so it isn’t out of the realm of possibility that there would be some light creeping in on the corners of the frame.
    Glenn
  • Glenn Sakatch
    February 25, 2017 at 5:02 pm
    Wow, I just downloaded the video…the stills don’t do it justice. The true fix is tracking and cloning frames.
    Maybe eyebrow on one pass, forehead on another. I didn’t realize it passed right over her face like that.
    Looks like a job for fusion and Mocha. Is this the only shot it happens on, or is the whole video like this?
    Glenn
  • Ron Fya
    February 26, 2017 at 7:53 pm
    Yes it is the only shot where this happens, and it’s pretty darn obvious and annoying … but since it is the final shot of the video, it is very important to have in clean … :-/
    Don’t know much about fusion and mocha though … so I think I am left with only the nuclear option of photoshop. 160 frames, 1 to 2 minutes per frame … that’s something like between 3 to 6 hours … yeah. Job is fun sometimes 😛
  • Ron Fya
    February 26, 2017 at 7:55 pm
    I like the idea of distracting using a flare though … maybe I should try that even though I suspect it won’t work since the shot is not moving so it will obviously look fake if a flare appears and disappears when the dust spot is the most noticeable.
  • Glenn Sakatch
    February 27, 2017 at 5:54 am
    Unfortunately frame by frame painting is extremely difficult to do..and not look obvious.
    I wish you luck.
    Glenn
  • Greuter Daysy
    November 3, 2018 at 12:47 pm
    Could this be efficient way to remove dust or a spot?
    https://youtu.be/IGI57CIbISE
  • Eric Santiago
    November 4, 2018 at 3:11 pm
    For music videos there are cheats I’ve had to witness (an attempt myself).
    One is to add an effect similar to the distraction idea.
    But more so noise and a texture look to simulate snow, dust, etc…
    Heck you can say its an artistic choice 😛
    LOL!
  • Michael Gissing
    November 4, 2018 at 9:57 pm
    There are various OFX clone shape plugins. Resolve has one plus I have other options with the Boris CC plugin suite. The old trick to manually overlay with offset and a mask is much more fiddly.
    I have also used the Boris pixel fixer OFX plugin to get rid of lots of small sensor dirt on some macro shots. Sometimes I needed up to 20 targets of small blobs to fix. You can’t do that as easily with layers. The good thing about sensor dirt blobs is they don’t move.
