Activity Forums Adobe After Effects Expressions getting “ReferenceError: Object is invalid” while resetting a listBox
  • getting “ReferenceError: Object is invalid” while resetting a listBox
    Posted by Dror Lazar on June 19, 2016 at 5:24 am
    Hi
    i’m trying to create a refresh button for a list (that shows the render Q better for my needs). it works fine, i’m removing all the list items and then re-entering them. for some reason when i click the same refresh button for the 6th/7th time i’m getting:
    (it seems to be related to line 66 in the code – ” curItem = folderPathListbox.add (‘item’, renderItem.toString()); // Column 1″)
    any help?
    i’m lost here…
    attached are the JSX and a sample project i use to test it:
    JSX – https://adobe.ly/1tC5jcj
    AEP – https://adobe.ly/1UfMfXF
    thanks
    D
    try{
    function createUserInterface (thisObj,userInterfaceString,scriptName){
    var pal = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName,
    undefined,{resizeable: true});
    if (pal == null) return pal;
    var UI=pal.add(userInterfaceString);
    pal.layout.layout(true);
    pal.layout.resize();
    pal.onResizing = pal.onResize = function () {
    this.layout.resize();
    if ((pal != null) && (pal instanceof Window)) {
    pal.show();
    return UI;
    {var res ="group {orientation:'column',\
    alignment:['fill','fill'],\
    alignChildren:['fill','top'],\
    headerText:StaticText {text:'Render Q lister', alignment:'center'},\
    buttonGroup: Group{\
    alignment:['center','top']\
    refButton: Button{text:'Refresh'}\
    dupButton: Button{text:'Duplicate Selected'}\
    selButton: Button{text:'Select in renderQueue'}\
    expButton: Button{text:'Export to File'}\
    folderPathListbox:ListBox{\
    properties:{\
    multiline:true,\
    multiselect:true,\
    numberOfColumns:5,\
    showHeaders:true,\
    columnTitles: ['Render #','Date','Time', 'Comp Name', 'Render Path']\
    function listRQ (rqList){
    try{
    var folderPathListbox = rqList;
    var proj = app.project;
    var totalRenderQ = proj.renderQueue.numItems;
    for(var i= 1; i<=totalRenderQ; i++){
    var totalOM= proj.renderQueue.item(i).numOutputModules;
    for (var om= 1; om<=totalOM; om++){
    var dateList, timeList, curItem, renderItem;
    renderItem = "Render #" + i + " - " + om ;
    if (proj.renderQueue.item(i).startTime != null){
    var min = proj.renderQueue.item(i).startTime.getMinutes() <10 ? "0"+ proj.renderQueue.item(i).startTime.getMinutes() : proj.renderQueue.item(i).startTime.getMinutes();
    var year = proj.renderQueue.item(i).startTime.getFullYear().toString().substr (-2,2);
    timeList = (proj.renderQueue.item(i).startTime.getHours()-1)+":" + min;
    dateList =proj.renderQueue.item(i).startTime.getDate()+"/"+(proj.renderQueue.item(i).startTime.getMonth()+1)+"/"+year ;
    }else{
    dateList = "not rendered";
    timeList = " ";
    curItem = folderPathListbox.add ('item', renderItem.toString()); // Column 1
    curItem.subItems[0].text = dateList.toString(); // Column 2
    curItem.subItems[1].text = timeList.toString(); // Column 3
    curItem.subItems[2].text = proj.renderQueue.item(i).comp.name; // Column 4
    curItem.subItems[3].text = proj.renderQueue.item(i).outputModule(om).file.toString().replace(new RegExp(",","g"), "\r").replace(new RegExp("%20","g"), " ").replace(new RegExp("%5B","g"), "[").replace(new RegExp("%5D","g"), "]"); // Column 5
    }catch(err){alert(err)}
    return folderPathListbox;
    var UI = createUserInterface(this,res,"Better RQ");
    var myList = UI.folderPathListbox;
    var lsRq = listRQ(myList);
    { // buttons action
    UI.buttonGroup.refButton.onClick = function () {
    lsRq.removeAll();
    UI.buttonGroup.dupButton.onClick = function () {
    alert ("Dup");
    UI.buttonGroup.selButton.onClick = function () {
    alert ("Sel");
    UI.buttonGroup.expButton.onClick = function () {
    alert ("Exp");
    catch(err){
    alert ("Error at line # " + err.line.toString() + "\r" + err.toString());
    Dror Lazar replied 10 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
