Activity Forums Apple OS X Getting Quicktime Sorenson codec back
  • Getting Quicktime Sorenson codec back
    Posted by Christina Rule on February 11, 2011 at 2:21 pm
    I recently purchased quicktime pro (Version 7.6.3) and I can’t seem to find the sorenson codec. In other versions of quicktime I remember you had to enable the codec within Quicktime (Quicktime Preferences, Advanced, Show Legacy Codecs.) However when I go to the preferences I don’t see the “advanced” tab anywhere. If anyone has any suggestions I’d appreciate it! Thanks in advance!
    http://www.christinarule.com
    Chris Fost replied 14 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Soyka
    February 11, 2011 at 2:48 pm
    On Mac OS X 10.6, this must be done on the command line. Open Terminal, then copy and paste:
    qtdefaults write LegacyCodecsEnabled yes
    Walter Soyka
  • Christina Rule
    February 11, 2011 at 2:50 pm
    Walter
    Thank you so much! I would have never guessed that!
  • Jeff Greenberg
    February 11, 2011 at 3:12 pm
    Just a footnote – if you don’t own the “pro” version of the Sorenson Codec, you’ll struggle with compression because there’s no VBR choices without purchasing the pro version of the codec.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Bob Sabiston
    November 1, 2011 at 7:42 pm
    Does this work in Lion? I just tried it and have not recovered Sorenson, Motion JPEG A, or others that I like.
    Do I need to do something else? I tried restarting.
    Bob
  • Walter Soyka
    November 1, 2011 at 7:46 pm
    Sorry, I’m not sure — I haven’t moved to Lion.
    Anyone else?
    Walter Soyka
  • Jeff Greenberg
    November 1, 2011 at 8:03 pm
    I ran the terminal command (as I had before) that walter mentions; Sorenson Pro (any version, as an encoder) doesn’t show up in QuickTime 7 as an exportable setting from QuickTime 7 Player.
    Meanwhile, I fired up compressor (4.0.1) and got nothing if I built an export setting for QuickTime.
    BUT, if I dragged a movie into compressor’s settings (which builds a preset), it built a preset with Sorenson 3. If I did it from scratch, nothing. So it seems it’s purposely off (as it’s an older legacy codec)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Bob Sabiston
    November 1, 2011 at 8:08 pm
    I think they are just doing what they can to kill off Sorenson in favor of h264. But Sorenson doesn’t have h264’s color weirdness where it’s always washed-out. And Sorenson works better with programs that deal with quicktime files on a frame-by-frame basis, I’ve found.
    Bob
  • Jeff Greenberg
    November 1, 2011 at 8:11 pm
    Both are fixable. h.264 is far more efficient in encoding.
    Install x264. I’m assuming you’re coming from FCP?
    Second, bump the keyframe rate to around every 15 frames; that will get you a bit more responsiveness.
    Best,
    Jeff G
  • Chris Fost
    June 18, 2012 at 10:00 pm
    Just found this out there on the web after much digging and wanted to share:
    “In OS X 10.7 Lion the codecs need to be enabled one by one. For Sorenson3 you type into Terminal: qtdefaults write LegacyVideoCodecs SorensonVideo3 enabled”
    It worked for me, I can now export Sorenson 3 from QT Pro 7.6.6 and more importantly (for me), Avid.
    Cheers,
    Chris
    Christopher Fost | Post Production Supervisor | Halifax, Nova Scotia, Canada
