Activity Forums Adobe After Effects Getting position values along a shape/mask path
  • Getting position values along a shape/mask path
    Posted by Will Poillion on August 9, 2019 at 12:42 am
    Hi guys, I was hoping to get some help with something. I feel like it’s easier than I’m making it.
    I’m trying to create a rig of sorts. I have a simple shape, divided into multiple paths (or masks in this case). What I want is to create a simple 0-100 slider that controls a position value. This position value starts at one end of the path and ends at the other. Simple enough right?
    I can offset trim path and move a segment (or a point) along the path, but that doesn’t give me the actual position values. And even if I could I really just want a single point along the path, not a segment.
    What I’m trying to do is add a particle emitter (stardust) to a point along the path and animate that point along it. I can set the entire path as the emitter as seen on the right, and I can use the trim path functionality to get it down to nearly a point as seen on the left and animate the offset. But it just loops the path over and over which doesn’t give me the control I want. More importantly without the position value for where it is on the path I can’t attach other things to it. And since stardust only samples the path at a set frame I can’t animate the path and have the emitter follow it.
    I need some sort of expression rig with two controls, one keyframeable 0-100 slider and one position slider that I can link to from my emitter (or anything else).
    Thanks guys! Seems like it should be easier than I’m making it but I’m just not seeing it.
    Walter Soyka replied 7 years, 1 month ago 2 Members · 1 Reply
