Activity › Forums › Apple Final Cut Pro Legacy › Getting out of memory errors while rendering (5gig ram)
Posted by Anders Haavie on August 2, 2007 at 7:50 pmI’ve got a brand spanking new quadcore with 5 gig ram with all the latest updates. (10.4.10-fcp6.01 etc..etc.) I am doing lots of color correction on a concert. I use magic bullet look suite and digital filmtools. Finalcut hangs after about 10 minutes of rendering with Out of memory error message. The solution is to render just a small piece of the timeline and repeat this process.
I have 5 gig ram so I guess that shouldn’t be a problem. Anyone else seen this behavour ?
Anders
Mark Maness replied 14 years, 10 months ago 12 Members · 13 Replies -
Tom Daigon
August 2, 2007 at 8:05 pmYes, I have a G5 with 2 gigs and it happened when I tried to load
a simple tutorial sequence from Diane Weynands book on FCP6. But it was just this ONE sequence, every other sequence on the books dvd loaded just fine…. -
Mark Maness
August 2, 2007 at 9:09 pmThe problem is your memory. Mac Pro systems run entirely differently than G5 systems. Memory is a majorly important factor when using a Mac Pro system. Take a look at this document from Apple on this issue with FCP.
https://docs.info.apple.com/article.html?artnum=304492
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Pxlmvr
August 3, 2007 at 6:04 pmActually, I get that on my dual 2Ghz G5 with 4GB of ram. Not sure why either.
Eric Grush
August 3, 2007 at 7:06 pmI am running a Dual 2.7 PowerPC G5
and have been struggling with this as well.
I have 6.5 gigs of RAM and whenever I try to
render large files it gives the same Out of Memory
failure. I can render for hours at SD, but only about
30min. in HD. My thought is that it is not simply a RAM
size issue. I have very fast SATA RAIDs and don’t think it’s
the drives. I had thought it was simply a throughput issue
in my older machine, but if you’re getting the same error on
newer machines then it must be something else. -
Mathias Theissen
August 4, 2007 at 10:35 pmI’ve experienced this problem with fcp on powerpc processors since fcp 4.5.. Added a bit more detail in this post
Patrick Troy
August 6, 2007 at 2:44 amI too am getting this error.
On a dual quad with 4gb ram
rendering ProRes -
Sean Oneil
August 6, 2007 at 8:13 am[Anders Haavie] ”
I have 5 gig ram so I guess that shouldn’t be a problem. Anyone else seen this behavour ?”You’re not supposed to have 5 gigs in a Mac Pro.
Look at the doc Wayne posted.
Sean
Scott Barker
October 6, 2009 at 8:29 pmI’ve got a 17″ macBook Pro 2.5 4gb and I just quit final cut and opened it again. seems to work alright for now.
Sam Roberts
December 13, 2010 at 8:17 pmIf you are rendering and re rendering the same shot, especially if there are large still photos in the timeline the memory gets overwhelmed.
Go to your render file for the project and delete all the renders, remember that there may be more than one render file for a project.
Your timeline will now be unrendered, simply re render the whole timeline again.
Yes FCP is totally lame because it can’t use all the memory you have in your computer, just one more thing on a very long lame list.
Michael Wiser
September 8, 2011 at 4:38 pmYour post spoke to exactly what i was doing. and I tried what you said but it still didn’t work. Now my whole sequence is in the red and and I can’t render it. give me the out of memory error.
