Activity Forums Apple Final Cut Pro Legacy Getting “Out of Disk Space” message
  • Getting “Out of Disk Space” message
    Posted by Scott Herriott on December 28, 2011 at 4:51 pm
    I have a 92 minute sequence, shot in HD, that I’m trying to export as a QT movie. I have 34 GB of space on my hard drive and, yet, I’m getting the error message. Is it possible it needs more than 34 GB or could there be another cause?
    Thanks in advance,
    Scott
    Scott Herriott replied 14 years, 8 months ago 2 Members · 2 Replies
  • David Roth weiss
    December 28, 2011 at 5:22 pm
    A few things you need to consider Scott…
    First, you haven’t mentioned what codec you’re trying to export to, so calculating the disk space required cannot be done.
    And, you must always consider the following factors when you fill a drive so close to total capacity.
    1) Whenever exporting a file, a temp file is written first, and that essentially means that you need the space for two files, not just one.
    2) The empty space is not contiguous, especially when nearly full, it’s instead tiny tracts of empty space that the OS must find and write to individually, thus slowing the process to a comparative crawl.
    Most here export a self contained file first, then use that as a master to create web delivery files and MPEG2 encodes for DVDs. It’s much quicker, and less prone to issues. You should do that too, but first clear some space on that drive or get a new one.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Scott Herriott
    December 28, 2011 at 5:25 pm
    Thanks David…excellent detailed advice.
