Activity › Forums › Compression Techniques › Getting Motion Jpeg Compression
  • Getting Motion Jpeg Compression
    Posted by Matthew King on October 28, 2010 at 2:19 pm
    I have a client that needs videos compressed to Motion Jpeg to be shown in movie theatres. I have been able to do this before when I was running Quicktime 7 but now I’m running Quicktime 10.0 on a MAC OS X Version 10.6.4. I know before you were able to go into the System Preferences and enable the legacy encoders for quicktime. But now when I go there, there isn’t an option for Quicktime at all.
    Is there a way that I can still get the Motion Jpeg codec so I can go into Final Cut Pro or Compressor and pick it as an option?
    I would love to use another codec but the theatre only likes JPEG 2000 (which when I export doesn’t play smoothly) and Motion Jpeg.
    Any help or suggestions would be most helpful. Thanks!
    Andrew Saliga replied 15 years, 10 months ago 3 Members · 2 Replies
  • Daniel Low
    November 14, 2010 at 11:05 pm
    Google + QT7 Pro.
    Simple.
    Sent from my iPad Nano.
  • Andrew Saliga
    November 18, 2010 at 11:00 pm
    QT7 Pro Should still be on your system. I believe it gets put into the Utilities folder…also I recall an option on the OS update disc to install it.
    I hope this helps you a little, but, yes, Google is your friend. 🙂
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
