Activity Forums Adobe After Effects Expressions Getting Media Start from imported file
  • Getting Media Start from imported file
    Posted by Paul Curtis on April 5, 2013 at 8:36 am
    This is a scripting/expression question and it’s really got me stumped. I have hundreds of comps to script and the base layer are MTS files. I need to generate each comp using the same timecode as the base layer.
    However i’ve not been able to work out how to read the start time code for a footage item.
    If i import the MTS and manually drag it onto a Comp that works
    If i expand the project window i can see Media Start/In Point for the footage and that’s correct
    However i’ve not been able to get these values in expressions or scripting form, i’ve found no reference anywhere and everything i’ve tried has failed so far.
    Help!
    Many thanks
    Paul
    Ben Insler replied 11 years, 7 months ago 2 Members · 1 Reply
  • Ben Insler
    January 21, 2015 at 6:04 am
    did you ever figure this out? I’d love to be able to read a layer/comp start timecode. Thanks!
