Activity Forums Adobe After Effects getting masks to work together.
  • getting masks to work together.
    Posted by Malcolm Desoto on July 5, 2007 at 5:10 pm
    So, here’s the deal. I’m masking out this door in order to show a different room in the BG. My only issue is that I need to mask both above and below his arm. I was going to use two mask and just key frame them as I go.
    masks
    However, eventually he removes his arm from the frame and the top and bottom masks need to merge or overlap. My only problem is that I can’t get these masks to overlap without excluding some other part of the alternate mask. I’ve tried different layer modes, inverting the mask.
    What am I missing here? I know it’s got to be some simple setting.
    Thanks.
    Malcolm Desoto replied 19 years, 2 months ago 16,116 Members · 1 Reply
  • Malcolm Desoto
    July 5, 2007 at 5:56 pm
    okay, okay, okay.
    I just needed to adjust the layer mode for the top masks.
    Thanks for the emotional support.
