Activity Forums Adobe After Effects Getting Hue Lightness Saturation colors right in AE
  • Getting Hue Lightness Saturation colors right in AE
    Posted by Marc Nibor on January 31, 2017 at 6:54 pm
    What is the approach to correctly resemble an RGB value, in AE with Hue Lightness Saturation?
    In the past I usually eyeballed it, because whatever I tried, I never got it right with any of the conversion tools. They colors looked way off when I was using them…. I guess I am doing something wrong.
    Right now I am working with a template. There is an item in the project and it’s color is supposed to be controlled via a control layer with hls controls.
    I need to change the color of this item to a specific rgb value. If I do it by hand I get close…. but I thought that conversion tools like this one https://www.rapidtables.com/convert/color/rgb-to-hsl.htm should work. On the site the result looks perfect. But If I enter these Values in AE it looks waaaaay off. What am I doing wrong?
    Marc Nibor replied 9 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 31, 2017 at 9:21 pm
    The template may be set up such that your HSL inputs are adjustments to some existing value, not absolute inputs themselves. If you wanted to hit a specific RGB value, you might have to change the color of that element some different way — perhaps its native color controls or a Fill effect.
    Of course, you can also do it by hand, using the controls the template makes available to you.
    This expression for a color sampler readout might help you:
    https://blogs.adobe.com/creativecloud/color-sampler-using-sampleimag/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Marc Nibor
    February 1, 2017 at 10:11 am
    Thank you very much Walter. As always from you – a very helpful and professionally thought through answer!
