Activity Forums VEGAS Pro getting green frames on good footage
  • getting green frames on good footage
    Posted by Joao carlos Schwalbach on March 16, 2011 at 12:59 pm
    I am editing this doc and from time to time I get some green frames in some of the clips. Most of the time, if I close and re-launch Vegas the green frames disappear but same times they don’t.
    Is this a known issue with Vegas Pro 10?
    Footage is from EX sony cams.
    Thanks in advance
    kind regards
    Joao carlos Schwalbach replied 15 years, 6 months ago 4 Members · 11 Replies
  • 11 Replies
  • Steve Rhoden
    March 16, 2011 at 4:15 pm
    No, that is not a known issue with Vegas. Maybe you have
    a codec issue on your system. What format are these files?
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Joao carlos Schwalbach
    March 16, 2011 at 4:25 pm
    Steve,
    This were .mov files from mac, converted to .mxf with Convergent Design’s FileConverter.
    Everything is fine when I import the clips into Vegas, but when I start editing, moving clips on trimming I get these ramdom green frames.
    Where can I look to find what’s wrong?
    kind regards
    [Steve Rhoden] “No, that is not a known issue with Vegas. Maybe you have
    a codec issue on your system. What format are these files?”
    March 16, 2011 at 4:40 pm
  • Steve Rhoden
    March 16, 2011 at 4:43 pm
    If possible, Try converting those files instead to
    a quicktime format (eg:Photo-jpeg)….And test if
    you still see hints of green popping up.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
    March 16, 2011 at 4:47 pm
    Steve, is there a way to batch convert these files to a quicktime format?
    Will I have to edit everything from scratch? (this would be hell, its 3 hours of footages X 3 cameras.
    thanks
    [Steve Rhoden] “If possible, Try converting those files instead to
    you still see hints of green popping up.”
  • Danny Hays
    March 16, 2011 at 8:10 pm
    Have you tried just editing the .mov files?
  • John Rofrano
    March 17, 2011 at 2:30 pm
    [Joao Carlos Schwalbach] “This were .mov files from mac, converted to .mxf with Convergent Design’s FileConverter.”
    That was a critical piece of information that you left out when you said, “Footage is from EX sony cams.” I thought you were working with native MXF files.
    [Joao Carlos Schwalbach] “Where can I look to find what’s wrong?”
    I would start looking at the Mac. Your trouble started when the Mac couldn’t handle the native XDCAM footage and munged it into someything unusable on a PC.
    I would use the original XDCAM footage directly from the Sony EX camera captured with Vegas Pro and take the Mac out of the equation and all of your problems will disappear.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
    March 17, 2011 at 9:07 pm
    Vegas can’t read the .mov files because they were captured on a mac.
    [Danny Hays] “Have you tried just editing the .mov files?”
    March 17, 2011 at 9:08 pm
    March 17, 2011 at 9:14 pm
    Hi John,
    Next time I will do that. In this particular case it is too late: the original footage is gone…deleted a long time ago. The footage was done by another company and they were suposed to do the editing as well but then things changed.
    Is there a work around to fix this?
    Could I export it to another format and get put it back into vegas without loosing the edit I have done so far?
    I haven’t tried to export it to see if the green frames are still there…will check that out tomorrow and post back.
    thanks once again
    regards
    [John Rofrano] “I would use the original XDCAM footage directly from the Sony EX camera captured with Vegas Pro and take the Mac out of the equation and all of your problems will disappear.
