Activity › Forums › Apple Final Cut Pro Legacy › Getting Flutter when slowing down footage.
  • Getting Flutter when slowing down footage.
    Posted by Steve Cohen on November 23, 2013 at 3:55 am
    I’m working on a spot in FCP 6 with footage that was shot on a Canon 6D in H264 in a mode called ALL-I. It was shot 1920 x 1080 at 29.97fps
    I converted the footage in Compressor to Apple ProRes and kept it at 1920 x 1080 at 29.97fps.
    The footage looks great at normal speed but when I try to slow it down I get a bad flutter.
    My time line is 1920 x 1080 at 29.97fps Apple ProRes.
    What can I do to get rid of this flutter. I tried De-Interlace, Flicker Free and Shift Fields and I can’t get rid of it.
    Thanks for the help.
    Steve Cohen
    Steven Cohen replied 12 years, 10 months ago 4 Members · 4 Replies
  • Nikolas Bäurle
    November 23, 2013 at 12:15 pm
    Depending on how much you slow-mo the flutter is normal, going under 30% will give you that effect. Frame blending can compensate some, but will start looking ugly at a certain point. You should try Twixtor to smooth that out. I use FCPX which has the option of optical flow that works very well.
    “Always look on the bright side of life” – Monty Python
  • Steve Cohen
    November 24, 2013 at 3:20 am
    Thanks. When I did 20% slowdown it looked OK, but I need to go slower than that. Like 50%.
    I’ll take a look at Twixtor.
    Steve Cohen
  • Michael Gissing
    November 24, 2013 at 11:13 pm
    da Vinci 10 lite (free) now has optical flow slo mo in its edit timeline. Motion also has optical flow slo mo. Lots of options for free although I have heard excellent reports about Twixtor.
    Frame blending is one of those things that needs to be experimented with but FCP in general is not a good tool for slo mo speed changing
  • Steven Cohen
    November 24, 2013 at 11:27 pm
    I tried a demo version of Twixtor last night and it worked great.
    It is expensive thought. I might try the others.
    Steve.
