Activity › Forums › Apple Final Cut Pro Legacy › Getting File Maker Pro to speak to FCP
  • Getting File Maker Pro to speak to FCP
    Posted by Scott Davis on August 24, 2009 at 2:40 pm
    Is there a way to get information out of a FMP database and into FCP via XML? We have an exhisting FMP database that I would like to get certain bits of info attached to their respective clips. Item IDs have been established that match in for FMP and FCP allready. We want info such as archive source to attach to the item and go in the “Master Comment 1” column.
    Andreas Kiel replied 17 years, 1 month ago 2 Members · 1 Reply
  • Andreas Kiel
    August 24, 2009 at 6:00 pm
    Yes you can do. Create a script within FMP that creates a valid FCP XML. You can read the FinalCutPro XML PDF to learn about how to do.
    One major thing you have take care about is the ‘updatebehavior’ to replace values. With FCP 6 you will probably get updated clips, but the are not in the bins they had been before. With FCP7 they will stay there.
    It would take to long to explain everything here.
    Hope that’s a starting point for you.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
