Activity › Forums › Apple Final Cut Pro Legacy › Getting Blackmagic NTSC from Intensity to work with FSI Monitor
Posted by John Davidson on November 22, 2009 at 3:34 amHello I just purchased a Mac Pro and a Decklink Extreme. I installed the Decklink and hooked it up to a Flanders Scientific monitor SDI in. I opened a project in Final Cut and when I go through the Audio/Video settings for Blackmagic DV, the video playback tab has [missing] Blackmagic NTSC in it. What have I done wrong? Needless to say I am not getting a picture to the Flanders. Thank You.
Ken Jones replied 16 years, 10 months ago 4 Members · 8 Replies -
Shane Ross
November 22, 2009 at 5:44 amTry uninstalling then reinstalling the drivers. Make sure you get the latest ones. Somehow your computer isn’t detecting the Decklink card.
Shane
Read my blog, Little Frog in High Def -
John Davidson
November 22, 2009 at 7:29 amHello Shane, I went back in and reinstalled the software. It did seem to resolve the Final Cut issue, but the signal to my monitor is all scrambled. Also when I now have the playback set to Blackmagic NTSC 8 bit the timeline drops frames and loses sound. If I say the output is none then it runs fine. Now I can’t believe this new Mac Pro 2X2.26 Quad Core Intel Xeon with 8 GB & 1 TB of ram is not fast enough for the DV sequence, is it?
Thank You for helping.
John -
Walter Biscardi
November 22, 2009 at 1:20 pmWe have a BlackMagic forum, I would post your query over there.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Ken Jones
November 22, 2009 at 5:44 pmHave you checked your Blackmagic settings in “System Preferences”? This is where you set the video and audio output connections and also the input and output processing (up-convert, down-convert). Perhaps one of these settings needs to be changed?
John Davidson
November 22, 2009 at 8:25 pmHello Ken, I went to the preferences menu and it ids set for SDI & HDMI & NTSC/Pal (Y out} & S Video out.
I am going into the 1 input SDI position on the Flanders monitor. I also tried position 2 SDI in to no avail. Just as a side note, If I make the video out in the Final Cut say none then it plays this DV sequence fine. As soon as I put it to Blackmagic NTSC 8 bit it drops frames and stops. Also if I mute the audio tracks it plays through the timeline fine, no dropping of frames.Thank You,
John -
Ken Jones
November 22, 2009 at 11:48 pmAgreed that this needs to be in the Blackmagic forum, but…
Do you have a Decklink Extreme (as stated in your post), Intensity (as stated in your subject line), or Intensity Pro?
Neither of the Intensity cards has SDI out.
Intensity has HDMI I/O only.
Intensity Pro has HDMI, component, and composite I/O.
Decklink HD Extreme has SDI, HDMI, component, and composite I/O. -
John Davidson
November 23, 2009 at 12:28 amHello, First off I appreciate the help. I have a Decklink HD Extreme. In the preferences it only gives me to choices out, SDI & HDMI & Y,R-Y,B-Y, and SDI & HDMI & NTSC/PAL (Y out) Pal.
Thanks Again,
John -
Ken Jones
November 23, 2009 at 12:33 amThe only thing I can think of is to check to make sure you are connected to one of the SDI “out” on the back of the Decklink HD Extreme card. The SDI I/O aren’t labeled (on my card at least) so look in the Decklink manual.
