Activity Forums Media 100 getting bins out of Media 100i into a Media Composer
  • getting bins out of Media 100i into a Media Composer
    Posted by Michael T. on August 9, 2005 at 8:20 pm
    Anyone out there have any experience in taking a project from a media 100i system into an avid media composer 11.2.6 running on Mac os9.2. Is there a way to export bins that have bin created in media 100i so that I can import and redig the material on the media composer? Thanks for your help.
    bouke Bouke replied 21 years, 1 month ago 2 Members · 2 Replies
  • bouke Bouke
    August 14, 2005 at 11:09 am
    Set your bins in list view, select all and copy, paste in a text editor.
    Now from here it’s easy to convert them to a .ale file.
    I assume you know the routine, but just in case, an ALE should look like this
    Heading
    FIELD_DELIM TABS
    VIDEO_FORMAT PAL
    AUDIO_FORMAT 48khz
    FPS 25
    Column
    Name Start End Tape Tracks Scene Customname1 Customname2
    Data
    1 17:15:38:16 17:15:58:18 GVL17 VA1A2 Chantilly totaal bib met td en licht uit?
    2 17:16:38:02 17:16:50:15 GVL17 VA1A2 Chantilly binneplaats pan
    or, alternative,
    Heading
    FIELD_DELIM TABS
    VIDEO_FORMAT PAL
    AUDIO_FORMAT 48khz
    TAPE myTape01
    FPS 25
    Column
    Name Start End Mark IN Mark OUT Tracks Comment
    Data
    01:17:47:21 01:19:28:14 01:17:48:21 01:19:27:14 VA1A2 goffertpark en stadion en openluchttheater
    hth
    bouke
  • bouke Bouke
    August 14, 2005 at 11:10 am
    Mind you, M100 DOES NOT store sequences in bins. They are stored seperate. If you want to redig a sequence you must go trough an EDL.
    bouke
