Activity Forums Compression Techniques Getting back into compression again need advice, and can a wmv file ever become a mov file?
  • Getting back into compression again need advice, and can a wmv file ever become a mov file?
    Posted by Todd George on May 6, 2005 at 8:34 pm
    Hello all
    just landed a new job at a university in Ohio, my background is corporate video and I had some experience in making mpeg1 files through cleaner 5x for use in power point presentations
    I need some advice on good reading material for compression is codec central stilla website?
    also I have a wmv file from the women’s basketball team that I wanted to convert to an mov file so that I could get it into either fcp4.5 or dvdsp3 ultimately it needs to go onto a dvd any advice
    thanks
    Todd George
    Mac PowerbookG4 (1.5mhz with 1 gig o ram) and Powermac G5 (1.8ghz with 1.5gigs o ram)
    fcp4.5
    motion 1x
    dvdsp3
    cleaner6x
    lightwave8x
    Charles Simonson replied 21 years, 4 months ago 4 Members · 3 Replies
  • Ben Waggoner
    May 6, 2005 at 11:21 pm
    Compression Master 3.1 can do .MOV to .WMV. It’s the most flexible encoding tool on the Mac today.
    The other good solution is Sorenson Squeeze, which focuses on ease of use.
    Unfortunately, Autodesk appears not to have done any engineering on Cleaner for nearly two years. It hasn’t been officially cancelled, but there haven’t been any signs of life either.
    My Book: https://www.benwaggoner.com/books.htm
    Squeeze and ProCoder tutorials: https://www.classondemand.net/benwaggoner/
    Compression Class at Stanford: https://www.digitalmediaacademy.org/compression.html
  • Craig Seeman
    May 6, 2005 at 11:32 pm
    Flip4Mac Studio can go from MOV to WMV and WMV to MOV. The WMV encoder plug in can be used in QuickTimePro, Cleaner, Sorenson Squeeze 4.1 (as well as Final Cut Pro, Final Cut Express, iMovie).
    Flip4Mac
  • Charles Simonson
    May 7, 2005 at 3:47 am
    Todd, welcome back! 😉 The F4M Player plugin will also allow you to do straight WMV imports into FCP. Of course, you will have to render it once you do to whatever timeline codec you’re working in, but it is a rather simple solution.
