Activity Forums Adobe Premiere Pro Getting audio off a DVD
  • Getting audio off a DVD
    Posted by Brian Dugan on October 23, 2007 at 1:46 am
    Hi. I have a DVD that I need to grab some audio off.
    It’s corporate thing I slapped together last year and don’t have the original working files.
    The DVD itself just has 2 folders AUDIO_TS (empty)
    and VIDEO_TS with files such as: VIDEO_TS.BUP, VIDEO_TS.IFO,
    and VTS_01_1.VOB.
    All jibberish to me.
    I have a iMac with Premiere and After Effects.
    Which also has an internal Mic but I tried just capturing while the DVD played but the volume was extremely low and the ambient noise was way too high.
    Any other ideas?
    Brian
    Scot Sheely replied 18 years, 11 months ago 4 Members · 3 Replies
  • Blast1
    October 23, 2007 at 1:57 am
    Get a analog to digital converter like a Canopus ADVC110 and play the DVD into it and capture the firewire output and then separate the video and audio, or you could play the sound into the line input of your sound card if it has one, or you could buy a little two channel USB mixer, seems if you were making corporate videos you should have some aux. equipment
  • Kanturina
    October 25, 2007 at 8:45 am
    Rename vob extension to mpg and import in premiere.
    That’s all.
  • Scot Sheely
    October 27, 2007 at 8:00 pm
    Brian,
    I agree with Kanturina. Renaming a .VOB (video object) file to an .m2v is the simplest method of operation here, and works well most of the time.
    Another possibility would be to use Adobe Audition (if you have that as well). You can capture audio from video directly using that program. Go to the FILE->OPEN AUDIO FROM VIDEO. If it is a very long program, it can take a while to capture into Audition.
    Finally, if you have a PC available to you for this task, you could use an excellent program called Total Recorder. Anything you can hear on your computer’s speakers, it can capture.
    Rather than being an analog means of capturing, it actually taps into your soundcard’s digital output and diverts (splits) the audio there to Total Recorder. So the sound is pristine and undistorted, with no additional D/A or A/D conversion necessary. Very, very cool program, and it has saved my rear on numerous occasions.
    FYI, Total Recorder runs with very little resources (as compared to Camtasia Studio, which is a huge memory hog!). You also still hear the audio coming from your speakers normally, so it changes nothing during playback and capture. Best of all, it supports a wide range of audio file formats.
    Scot
