Activity › Forums › Apple Final Cut Pro › Getting an FCP X XML from a title stream…
Posted by David Battistella on September 6, 2012 at 3:27 pmOK,
I have a 23 minute film with subtitles in FCP X.
I want an XML or EDL of just the title locations to pass on for the ONLINE.
Any takers on the best, most efficient way to accomplish this?
David
______________________________
The shortest answer is doing.
Lord Herbert
https://www.davidbattistella.comDavid Battistella replied 13 years, 11 months ago 2 Members · 5 Replies -
David Battistella
September 6, 2012 at 3:44 pmSOLUTION:
Copy all of the text from the FCP X Timeline.
create a new project
paste it into the new project and set the first title to match the TC from where you pasted.
Export FCP X XML
Convert in FCP X to 7
Open in FCP 7
Surprisingly all of the text is there as well. Cool!
Lord Herbert
https://www.davidbattistella.com -
Andreas Kiel
September 7, 2012 at 9:08 amSome other solutions.
If you got “pre-rendered” titles use EDL-X
https://xmil.biz/EDL-X/EDL-X.shtmlWith standard “typed-in” titles you can use my XTE to convert a FXCPXML to STL. It comes as free app with my TitleExchange.
https://www.spherico.com/filmtools/TitleExchange/TitleExchangePro_SL.dmg-Andreas
Spherico
https://www.spherico.com/filmtools -
David Battistella
September 7, 2012 at 11:01 amAnreas,
I should have added that I did use your tool. Title exchange and was able to open these files in Jubler as well.David
Lord Herbert
Andreas Kiel
September 7, 2012 at 11:17 amOkay,
But the workflow you described has “too many” steps 😉
Here what would be mine.
Export the whole project as FXPXML.
Open the XML with XTE and save.
Open the saved STL in Jubler.It’s just a few seconds.
With XTE you also can control subs by their role. This makes it easy to control different languages. Also time collisions are handled.-Andreas
Spherico
David Battistella
September 7, 2012 at 9:16 pmYou are right. This is much smarter and faster and much more what I would expect from FCPX xml files.
I think I have been so beaten down at doing workarounds theis past year that I forget to check if there is an elegant solution that works with FCP X and yours works perfectly.
I could have saved a bunch of time using this very professional and efficient tool.
Thanks for the heads up!
David
Lord Herbert
