Activity › Forums › Adobe After Effects Expressions › getting an expression from a text layer (source text)…?
  • getting an expression from a text layer (source text)…?
    Posted by Erin Shelby on January 11, 2007 at 11:38 am
    I was wondering if I wrote an expression in a text layer (the source text, that is), if I could make another layer use the string within it? I tried through the pick whip but that didn’t work.
    For example let’s just say the text layer source text string is:
    [10,10];
    then on another layer I want the position property expression to use the source text string…what would that expression be? TIA.
    -E
    Erin Shelby replied 19 years, 8 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 11, 2007 at 3:20 pm
    The code is going to depend a lot on the format of the text, but for your example something like this should do the trick:
    eval(“s=” + thisComp.layer(“Text Layer”).text.sourceText);
    Dan
  • Mylenium
    January 11, 2007 at 4:08 pm
    In case you want to use your numbers in calculations, you may also want to use parseInt() and parseFloat().
    Mylenium
    [Pour Myl
  • Erin Shelby
    January 20, 2007 at 5:21 pm
    wow thanks, that helped me quite a bit…if I could up the complexity, would there be a way so I could make different expressions grab from different lines of the source text? Or is that just too complex?
