Activity › Forums › Adobe After Effects Expressions › Getting active layer count at current time
Posted by Fletcher Groeneman on August 14, 2014 at 9:24 pmHello CreativeCow community!
I am trying to have a text layer’s Source Text be the number of active layers above itself at the current time.
The number would change as you scrub through the timeline and more or less layers become visible.
Thank you for your help!
Brie Clayton replied 2 years, 11 months ago 5 Members · 11 Replies -
Dan Ebberts
August 14, 2014 at 10:09 pmTry this:
n = 0;
for (i = 1; i < index; i++)
if (thisComp.layer(i).active)
n++;
n
Dan
Fletcher Groeneman
August 14, 2014 at 10:13 pmWorks perfect. Dan, you are the best!
Many, many thanks.
If you have time, could you walk me through that expression… I would love to understand what is happening so I can modify and re-use it in future work.
– Fletcher Groeneman
Dan Ebberts
August 14, 2014 at 10:32 pmFletcher,
The expression just looks at each layer that has a layer index less than its own (which means the other layer is above the layer with the expression in the layer stack) and bumps a counter (n) for each active layer it finds.
Dan
Fletcher Groeneman
August 14, 2014 at 10:47 pmThanks Dan.
So let me try and interpret it:
for (incrementally by 1; every layer index smaller than my index)
if (that layer is active)
add 1 to a start value of 0Correct?
René Pedersen
December 7, 2022 at 2:22 pmHi
The last couple of days I have been – unsuccessfully – trying to expand this old expression.
The thing is that I don’t want to count active layers, but count all layers that has the term BlueBox in its name.
I remembered an expression I had used before from that uses a keyword (not to get a number, but to set a width) https://ukramedia.com/how-to-automatically-get-the-size-of-many-layers/
keyword = “ukramedia”;
widthList = [];
for(i = 1; i <= thisComp.numLayers; i++) {
layerPath = thisComp.layer(i);
layerWidth = layerPath.sourceRectAtTime().width;
if(layerPath.name.match(keyword)) {widthList.push(layerWidth)} else {};
Math.max(…widthList) + 100
But when I try to merge the expressions it doesn’t work. This is what I tried – any idea what am I doing wrong?
n = 0;
keyword = “BlueBox”
if (layerPath.name.match(keyword))
n++;
Dan Ebberts
December 7, 2022 at 5:11 pmThis should count all layers with BlueBox in the layer name:
n = 0;
keyword = "BlueBox";
for (i = 1; i <= thisComp.numLayers; i++){
if (thisComp.layer(i).name.indexOf(keyword) > -1) n++;
n -
Penelope Harpley
October 4, 2023 at 2:35 amHello all,
I’ve been trying to rejig the expressions in this post to work for my needs to no avail. Maybe I’m barking up the wrong tree? My javascript knowledge is minimal.
I’m trying to accumulate the width of multiple layers if they meet a condition.
In basic english:
Look through all layers with an index < current layer. If the opacity == 100, get width of current layer and add to a total.
Thanks in advance!
Dan Ebberts
October 5, 2023 at 7:31 pmLike this maybe:
total = 0;
for (i = 1; i < index; i++){
if (thisComp.layer(i).opacity == 100){
total += thisComp.layer(i).sourceRectAtTime(time,false).width;
total -
Penelope Harpley
October 13, 2023 at 1:14 amDan, thank you so much this works! You are a legend. I have learned so much from your work with expressions over the years, I can’t thank you enough for your contribution to this forum.
