Activity Forums Apple Motion Getting accurate aspect ratios from .psd’s and jpegs
  • Getting accurate aspect ratios from .psd’s and jpegs
    Posted by Samahcinema on September 26, 2007 at 9:07 pm
    When I bring in .psd files into my Motion project file (which has 720p settings) the image looks distorted- that is stretched out at the sides so everything looks fatter. What are the image dimension settings I would need to save the .psd file as to get the image to look true to life, or at least true to how the image looks in Photoshop?
    Thanks.
    Arnie Schlissel replied 18 years, 11 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    September 28, 2007 at 6:17 pm
    720 should be 1280X720. Your motion comp should have the same dimensions. Your output may have different dimensions, depending on codec. Motion will scale the ouput properly in most cases.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
