Activity Forums Apple Final Cut Pro Legacy Getting a square animation into my sequence
  • Getting a square animation into my sequence
    Posted by Henrik Helms on December 9, 2009 at 7:20 am
    Hi!
    I have received a 1920*1080 in animation codec in square pixel aspect.
    It is going to be fitted into a 1024*576 sequence uncompressed 10 bit.
    If I just put it into the sequence i think it gets a little bit blurry in the motions.
    What is the best way to get it into my sequence??
    Kind regards
    Henrik
    dBA MEDIA
    Henrik Helms replied 16 years, 8 months ago 3 Members · 3 Replies
  • Rafael Amador
    December 9, 2009 at 10:02 am
    Hi Henrick,
    Try setting “Render Motion Effects: BEST”. This should improve the downscaling.
    if you have the opportunity that they export the same animation from AE with the final size and in the final codec, the best.
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    December 9, 2009 at 2:24 pm
    1024×576 is not a video size. There is no tape format and no broadcaster that will accept it.
    If you’re trying to make a widescreen SD in PAL, that size would be 720×576. Look up “aspect ratio” in your FCP manual, it will explain how the pixels become stretched to make an anamorphic widescreen image using the same number of pixels as 4×3.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Henrik Helms
    December 9, 2009 at 3:21 pm
    I am well aware of the dimensions – well I ment anamorphic (which end up in the above dimensions) – but that does not change the aspect and dimensions of what I import…which is my problem…
    To get rid of the blury motion on a square animation codec in 1920*1080
    Kind regards Henrik
    Greetings
    Henrik Helms
    dBA MEDIA
