Getting a specific values from another composition marker
Hi !
I’ve been lurking in the forum to seek out the solution and got it, but unfortunately, I am missing something.
Basically I have a :
composition: A, containing a layer with a split marker that define a movement duration. The position of the marker is can and ;probably will, change
composition : B, containing the moving object.
So, I look to get the value of the object in comp B at the time of the marker in comp A
I thought this code a found on the forum would work, but I might be missing a lot
Thx for any help.
t = thisComp.layer("Cntrl Cam 002").marker.Key("markername001").time;thisComp.layer("Cntrl Cam 002").transform.orientation.valueAtTime(t);
//my version
t = Comp("_CONTROL_PANNEL_CTRL").layer("Grid_Preview").marker.Key("Move").time;
Comp("test").layer("Spin").transform.yPosition.valueAtTime(t);
