Activity › Forums › Apple Final Cut Pro Legacy › Getting a solid 10fps during playback using Animation codec
  • Getting a solid 10fps during playback using Animation codec
    Posted by Craig Williams on October 23, 2009 at 6:53 pm
    I am using iShowU HD to record a screencast. I can import the videos into FCP with no errors and no rendering required.
    iShowU settings:
  • Apple ProRes 422
  • Linear PCM
  • After editing, the videos must playback at a consistent 10fps in Animation codec. This is a requirement of the customer. When I export using either Compressor or FCP using QuickTime Conversion, the fps fluctuate between 0 and 10 during playback.
    I have had success using the H.264 – Webcasting setting in Compressor. Unfortunately, the customer will not accept this format.
    Is it possible to get a consistent fps during playback using the Animation codec?
    Computer Settings
  • FinalCut Pro 7.0
  • MacBookPro 2.6 GHz Intel Core 2 Duo
  • 4 GB ram
  • OS 10.6.1
Craig Williams replied 16 years, 11 months ago 5 Members · 11 Replies
  • 11 Replies
    • Alan Okey
      October 23, 2009 at 7:55 pm
      Animation is a high-bandwidth RGB codec. What is the resolution of your screen capture?
      If the video dimensions are large enough, it’s entirely possible that you won’t get consistent playback speed from a single drive due to the high data rate required to maintain smooth playback without dropped frames. If that’s the case, you may need to stripe several drives in RAID 0 to achieve the desired playback rate.
    • Craig Williams
      October 23, 2009 at 7:58 pm
      Full screen capture at 1024 x 768. I am still in the testing phase right now so the videos are around one minute in length.
    • Kevin Monahan
      October 23, 2009 at 8:07 pm
    • Alan Okey
      October 23, 2009 at 8:39 pm
      [Craig Williams] “Full screen capture at 1024 x 768. “
      That’s considerable. Drive speed and/or buffering to RAM speed are likely the bottleneck here.
    • Craig Williams
      October 23, 2009 at 8:52 pm
      Thank you both for the suggestions. I will give the ProRes 4×4 a shot and see what they say.
    • Tom Brooks
      October 24, 2009 at 1:58 pm
      PNG is another pretty nifty codec in 8-bit, like Animation. I believe you’ll get the frame rate you want with it and it’s lossless at 100%. Also comes standard with Quicktime. Check out what is said here:
      https://codecs.onerivermedia.com/
    • Craig Williams
      October 24, 2009 at 2:03 pm
      Thanks Dave.
      I spoke to the customer yesterday and they have decided to accept H.264. They came up with an acceptable workflow to convert it to the Animation codec.
    • Craig Williams
      October 24, 2009 at 2:05 pm
      Thanks for the link. Good information to have!
    • Dylan Murphy
      November 2, 2009 at 10:01 pm
      Craig,
      I’m in the same boat – do you know what they used to convert to solid 10fps animation?
      Much appreciated
    • Craig Williams
      November 3, 2009 at 12:07 am
      No, they did not say. I will ask them tomorrow and post back their response.
