Activity › Forums › Adobe After Effects › getting a pshop selection into after effects
  • getting a pshop selection into after effects
    Posted by Bill Hash on March 27, 2007 at 4:17 pm
    I have an after effects composition in which I want to drop 2dimension pics of the earth selected from pshop files
    How do I get just the selection (the earth) into the after effects comp without the white border?
    I Have a foglight (swirling foggy background in the comp) if I used a black background for the comp I could do that but the fog is necessary so how do I get rid if the border in making the selection into a new file?
    Bill Hash replied 19 years, 6 months ago 3 Members · 3 Replies
  • Darby Edelen
    March 27, 2007 at 6:04 pm
    [bill875] “How do I get just the selection (the earth) into the after effects comp without the white border?”
    Are you saying that the mask on your Photoshop layer isn’t exact? Or are you saying that the white ‘background’ layer in Photoshop is showing? If the latter: when you import your footage into After Effects make sure you don’t import the Photoshop file as “Merged Layers,” this will effectively flatten your file’s layers into one. Instead you want to choose a layer in the Photoshop file to import. Alternatively you could just delete the white ‘Background’ layer in Photoshop so that you can see the checkered pattern (meaning those pixels are transparent) behind the earth image.
    If you are trying to remove the earth from a layer with a white fill then you’ll just need to make sure your selection doesn’t include any of the white on that layer when you use Layer > Layer Mask > Reveal Selection.
    It’s hard to know exactly what the problem is without more information about the Photoshop file(s). I don’t know how many layers are in the file, if there’s an alpha channel, etc.
  • Mike Procunier
    March 27, 2007 at 6:56 pm
    A quick and dirty would be to use the “Simple Choker” effect in After Effects. Adjust the “Choke Matte” setting until the white pixels go away.
  • Bill Hash
    March 27, 2007 at 8:17 pm
    thanks guys i appreciate it i’ll try importing one layer first
