Getting a Premier Pro 5.5 Sequence to After Effects CS 5.5
I am new at both of these application and I am having a problem getting a complete sequence to the composition timeline. I go into AF and Import the Premier sequence into AF I can see the sequence and everything in it. When I try to place it below on composition time line it does not go . I have tried this also just importing the entire project as well. I want this sequence in the comp timeline so I can do motion graphics on stills and titling while I see the entire sequence. Is there another workflow I need to be doing.
What Am I doing wrong here
Mike
