Activity › Forums › Adobe After Effects › getting a full RAM preview
Posted by Malcolm Desoto on October 8, 2007 at 4:15 pmSometimes, my RAM preview will just start playing half way through although it has not completed the entire Preview.
Is it just running out of memory? Is there some setting I’m missing?
I’m previewing a 30 sec SD project at half res.
Dual 2.8, 4GB RAM
Thanks.
Malcolm Desoto replied 18 years, 11 months ago 5 Members · 17 Replies -
Steve Roberts
October 8, 2007 at 4:43 pmIt sounds as if you’re out of RAM. Check Activity Monitor (Mac) or Task Manager (Win).
Edit>Purge image caches every now and then.
Consider previewing every other frame.
Kevin Camp
October 8, 2007 at 4:48 pmthat would be normal when ae runs out of memory for the ram preview.
you may be able to render more if you hit the spacebar for previews… this will render the preivew to disk, however, play back may not be in realtime depending on the data rate of your dirve and the data rate of the file (high frame rates and large frame sizes can greatly effect the data rate needed to play the preview).
alternately, you may rather reduce the reslution and magnification on the the preview or even the frame rate of the preview in the time controls, this will allow you to fit more of your preview in the ram available.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Kevin Camp
October 8, 2007 at 4:52 pmas steve mentioned, in addition to altering the frame rate, you can set the preview to skip frames in the time controls panel… and that’s probably a bit easier than calculating a new frame rate….
Kevin Camp
Jimmy Brunger
October 8, 2007 at 7:30 pmI never thought of reducing the comp window size – does this really work? I’m still getting a full res preivew out of my decklink card to view previews, so this shouldn’t be affected should it?
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0 -
Malcolm Desoto
October 8, 2007 at 9:47 pmSorry, that’s what I meant. In addition to previewing at half res, I also decrease the comp window so that it looks better.
Steve Roberts
October 9, 2007 at 1:03 amThis has been recommended practice for a while, as it helped RAM preview work more efficiently. Or faster. Like I know.
It may not be necessary nowadays, as this was recommended when RAM preview first came out in … version 4.1?
Anyway, try it, see if there’s any difference.
Malcolm Desoto
October 9, 2007 at 2:32 amIt seems that AE was just acting up. I mean, all of your suggestions will surely help; but I just shut down the system for awhile, came back, and everything was working alot better.
It was kind of odd being that I had already restarted the computer once before with no improvement.
Anyway, I guess it just needed some personal time.
Thanks for all of your advice.
Steve Roberts
October 9, 2007 at 3:26 amDon’t forget to swing the bloody chicken around your head three times. 🙂 You’d think we were done with the computer voodoo, but it’s still a viable option in many cases.
