Activity › Forums › Adobe Premiere Pro › getting a blue screen when exporting to tape
  • getting a blue screen when exporting to tape
    Posted by Olwiggum on May 4, 2006 at 12:37 pm
    Hi all, I’ve done this tons of times, but I’ve had some problems the last few times that I’ve tried to export a video to my cameras.
    I get the PC plugged into the camera(s) using a firewire cable and start recording on the camera. It will record just fine for a few seconds, then drop out for a second or so and flash a bluescreen. It’s done this on the last 2-3 projects that I have worked on.
    I’m using Premiere Pro 1.0.
    Any idea what is causing this?
    Aanarav Sareen replied 20 years, 4 months ago 2 Members · 4 Replies
  • Aanarav Sareen
    May 4, 2006 at 4:41 pm
    Have you tried using a new/different firewire card or a different deck? Also, try switching cables…
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Olwiggum
    May 4, 2006 at 11:02 pm
    I’ve used different cables and 2 different cameras. I guess it’s the card then, huh?
  • Olwiggum
    May 4, 2006 at 11:50 pm
    Also, it doesn’t when I capture from the cam to the PC, only when I go from the PC to the cam. Would there be a solution to that?
  • Aanarav Sareen
    May 5, 2006 at 1:01 am
    Download an application called ScLive and try capturing via that. If that doesn’t work, then there is a hardware issue.
    Aanarav Sareen
